Error Assistant in API
When we open a SE document we have 'Error' button (by default disabled) in the Tools panel. When some error is there, it gets enabled. When we click it, it shows the description of what is wrong with the document.
Can this functionality of 'Error Assistant' be captured in VB API?
I don't see anything related to it in the members of document object or even application object.
If yes, how?
If not, is there any alternative?
Thank you for any help.
Posted by: Narantar Vidyarthee
Post date: 1/28/2012 8:29:26 PM
RE: Error Assistant in API
Unfortunately, not that I'm aware of. I suggest you contact GTAC and file an Enhancement Request (ER) for this functionality.
Posted by: Jason Newell
Post date: 1/29/2012 7:58:33 PM
