Error occurs while Rebuild Addin
Hi
i have created Add In for Solid Edge but while rebuilding the project i am having below Error
[color=#ff4400]The assembly "E:\Yogesh\Working Folder\SE AddIn new\VB .NET\SEAddIn\SEAddIn\bin\Debug\SEAddIn.dll" could not be converted to a type library. Type library exporter encountered an error while processing 'SEAddIn.Addin, SEAddIn'. Error: Element not found.[/color]
Posted by: Yogesh Shinde
Post date: 5/22/2012 4:37:22 AM
Re: Error occurs while Rebuild Addin
Did you give your addin class a guid attribute and mark it com visible?
Posted by: R.D. Holland
Post date: 6/26/2012 2:53:54 PM
