Reply
Export Geometry when no Parasolid info available
[ Edited ]
I am able to create an AutoCAD DXF file from a PartDocument when I can access the PartDocument.Models items. However, this item is not always available. I've encountered a situation where PartDocument.BodyCheck = false, which I thinks means that "PartDocument.Models is empty, so don't use it".
In such a situation, anybody know where you can get
1. List of faces, Edges, ...
2. what is the equivalent for Body.getFacetData
Chahé
Posted by: Chahe Adourian
Post date: 9/12/2008 2:22:43 PM
RE: Export Geometry when no Parasolid info available
[ Edited ]
Chahé
I haven't tried it but what about using Models.SaveAsFlatDXF()? If you want to upload an example file, I'll try to take a look at it.
Posted by: Jason Newell
Post date: 9/15/2008 7:15:48 AM
