Expose Variable
Can anyone tell me how to expose a variable using Visual Basic
Posted by: Eddie Miller
Post date: 12/17/2008 4:46:08 AM
RE: Expose Variable
Hi
Set Variables = objDoc.Variables
MaterialThickness = Variables.Item("MaterialThickness").Value
PlateArea = Variables.Item("Plate_Area").Value
Cheers
Snow
Posted by: Snow Mackenzie
Post date: 12/21/2008 6:02:03 PM
Re: RE: Expose Variable
How change a expose name of exist variable ?
Try this :
Variables.Item("MaterialThickness").ExposeName = "MatThick"
Variables.Item("MaterialThickness").Expose = True
Romuald
Romuald BERTIN
OK works fine, but it crush when variable have already expose name...
What i should do ?
The following code worksfine for me :
        Try
            _application = CType(Marshal.GetActiveObject("SolidEdge.Application"), SolidEdgeFramework.Application)
        Catch ex As Exception
            If Not (_application Is Nothing) Then
                Marshal.ReleaseComObject(_application)
                _application = Nothing
            End If
            MsgBox("Cannot connect to Solid Edge.")
            End
        End Try
        Try
            objDoc = _application.ActiveDocument
            If objDoc Is Nothing Then
                End If
                MsgBox("No active File.")
                End
            End If
            End If
            End
        End Try
        Dim objVars As SolidEdgeFramework.Variables = objDoc.Variables
        Dim objVar As SolidEdgeFramework.variable
        objVar = objVars.Item("MaterialThickness")
        objVar.ExposeName = "MatThick"
        objVar.Expose = True
Maube your problem is that another variable is exposed with the same name.
Romuald BERTIN
Hi Romuald,
Thanks i will check it later. I have another question, because still i have problem to expose flat pattern variable... i have ST6
                objApp = Marshal.GetActiveObject("SolidEdge.Application")
                If objApp Is Nothing Then
                    MessageBox.Show("Solid Edge should be running.", sTitle, MessageBoxButtons.OK, MessageBoxIcon.Error)
                    End
                End If
                objApp.Activate()
                objPartDocument = objApp.ActiveDocument
                objFlatPatternModels = objPartDocument.FlatPatternModels
                If objFlatPatternModels.Count > 0 Then
                    objFlatPatternModel = objFlatPatternModels.Item(1)
                    objFlatPatterns = objFlatPatternModel.FlatPatterns
                    If objFlatPatterns.Count > 0 Then
                        Dim oMaxCutSizeX As Double = 0.0
                        Dim oMaxCutSizeY As Double = 0.0
                        Dim oShowRangeBox As Boolean = False
                        Dim oAlarmOnX As Boolean = False
                        Dim oAlarmOnY As Boolean = False
                        Dim oUseDefaultValues As Boolean = True
                        For a = 1 To objFlatPatterns.Count
                            oshowdim = objFlatPatterns.Item(a)
                            Try
                                oshowdim.SetCutSizeValues(MaxCutSizeX:=oMaxCutSizeX, MaxCutSizeY:=oMaxCutSizeY, ShowRangeBox:=True, AlarmOnX:=oAlarmOnX, AlarmOnY:=oAlarmOnY, UseDefaultValues:=False)
                                If Not (objApp Is Nothing) Then
                                    Marshal.ReleaseComObject(objApp)
                                    objApp = Nothing
                                    MsgBox("Show cut size range and dimensions manually", MsgBoxStyle.Critical)
                                End If
                                Return
                            End Try
                        Next
Could you check my code for me.
Hi Lauren,
I haven't got any problem with your code.
What are you trying to do with it ?
This code only redefine the CutSize options that will set an alarm if the dimensions of the flatpattern are bigger than the max cut sizes.
Romuald BERTIN
I need a variable Flat_Pattern_Model_CutSizeX and Y do describe a plate dimensions
To do that first, i must show a cut size range, without this those variable are not active.
So i`d like to my macro do that.
Lauren,
you could try
oshowdim.ShowDimensions=True
to achieve what you want.
Then you should be able to expose the named variables.
Kind regards,
Wolfgang Kunert - www.wksyspro.de
