Fail to add balloon on PartDocument
I try try to add a ballon on a feature on a partdocument.
I catch the mouse click event (I set the filter on seLocateFeature)
When I add the balloon the function fail : nothing is created. Do you know where
is my mistake ?
Private Sub objMouse_MouseClick(ByVal sButton As Short, ByVal sShift As Short,
ByVal dX As Double, ByVal dY As Double, ByVal dZ As Double, ByVal pWindowDispatch
As Object, ByVal lKeyPointType As Integer, ByVal pGraphicDispatch As Object) Handles
Dim pmi As SolidEdgeFrameworkSupport.PMI
Dim b As SolidEdgeFrameworkSupport.Balloon
Dim bs As SolidEdgeFrameworkSupport.Balloons
pmi = docCour.PMI
bs = pmi.Balloons
' I try several method, b is always = nothing / no exception catch
b = bs.AddByTerminator(TerminatorObject:=pGraphicDispa tch, x1:=0.75,
y1:=0.05, z1:=0, keyPoint1:=True)
y1:=0.015, z1:=0, keyPoint1:=False)
b = bs.Add(0.1, 0.2, 0.1)
Catch ex As Exception
End Try
End Sub
Posted by: nicolas garet
Post date: 12/14/2009 9:25:53 AM
