Failed feature
Hi guys, I am writing a code to change the tolerance of dimension of solidedge oart file in vb.net. But while changing tolerance some of the feature may get fail. So how cal i get the failed feature from vb.net. We can get the suppressed feature by Issuppressed property of feature but what is method to know whether feature is failed or not. Can someone please help me with this??
Posted by: Chetan Sonawane
Post date: 7/29/2009 7:06:24 PM
RE: Failed feature
you have to use the Status property of the Feature object. See example below:
Dim Features As SolidEdgePart.Features = Doc.Models.Item(1).Features
For i As Integer = 1 To Features.Count
Dim Feature As Object = Features.Item(i)
Dim Status As SolidEdgePart.FeatureStatusConstants = Feature.Status
Dim Name As String
If Se.Version >= 16 Then
Name = Feature.DisplayName
Else
Name = Feature.Name
End If
Select Case Status
Case SolidEdgePart.FeatureStatusConstants.igFeatureFailed
Out.WriteLine(Res.GetText("Proof.Error") & ": " & _
Res.GetText("Proof.FeatureFailed") & ": " & _
Name, Indent + 1)
Case SolidEdgePart.FeatureStatusConstants.igFeatureSuppressed
Res.GetText("Proof.FeatureSuppressed") & ": " & _
Name, Indent + 1)
Case SolidEdgePart.FeatureStatusConstants.igFeatureWarned
Res.GetText("Proof.FeatureWarned") & ": " & _
Name, Indent + 1)
End Select
Next
Posted by: Wolfgang Kunert
Post date: 7/30/2009 12:09:10 AM
