Family of Assembly Member Properties
Does anyone know how to access all of the properties of FOA family members when the assembly is open in Solid Edge. I need both read and write access and at the moment can only access the ProjectInformation properties through AssemblyFamilyMember.MemberProperties.
Anyone got any ideas?
Cheers
Calum
Posted by: Calum McLellan
Post date: 3/3/2008 9:18:22 AM
RE: Family of Assembly Member Properties
Hi Calum,
I think you have to switch through all members and activate them ( e.g. in a foreach). Then get the Document or Part object and access the properties from the activated member. Hope this helps...
regards,
Sibi
Posted by: Seb Sosna
Post date: 3/4/2008 12:53:32 AM
Hi Sibi,
Thanks, I discovered that this morning when I did some more tests. It was then I realised that all my tests had failed up until now because my files were managed by Insight. For Insight managed files there is only one set of properties, unfortunately this is not the property set written to by SolidEdgeDocument.Properties.
I've logged this with GTAC. We'll see what they say.
Cheers
Calum
Post date: 3/4/2008 1:25:22 AM
