Feature status
Hello
I have trouble with the Features status
I make the Extruded protrusion and extruded cuttout.
I want to check if the cuttout is ok
[i]If objExtCut.Status = SolidEdgePart.FeatureStatusConstants.igFeatureOK Then
Console.WriteLine("OK No problem")
Else
Console.WriteLine("Issue!")
' Do this code...
'regen
End If[/i]
so and problem is in case, when the cuttout is placed out of protrusion /no interference/,
the status in not igFeatureFailed but there is a error {"Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))"}
any tips how to obtain igFeatureFailed status to do code in IF?
Posted by: Tibor
Post date: 8/6/2012 6:04:12 AM
