File Properties
Hi Jason,
Is it possible to get a handle to the SharePoint path of a mapped folder in My Network Places using the technique you have used for the File Props API. I am refering to a folder with a physical path pointing to the NetHood but with a http:// path in the comments column in Windows Explorer. I need the http path to find certain SharePoint files for the Explorer-like controls I have developed.
I haven't had enough time to really get into the documentation but I have a feeling this is possible - just thought you might be able to save me some reading
Posted by: Calum McLellan
Post date: 10/24/2005 9:01:31 AM
RE: File Properties
Solid Edge Find uses a bit of code from
It's in C# but you should be able to translate what you need to VB.NET.
Posted by: Jason Newell
Post date: 10/24/2005 1:34:41 PM
