File name for Save as PDF
Hello everyone,
I very often save drawing as PDF and DXF for laser cutting.
I would like to create alone macro for PDF and DXF.
I am programer biginer. I use MS VB 10 Express
My code now is:
Imports System.Runtime.InteropServices
Module Module1
Public seApp
Dim dftDoc As SolidEdgeDraft.DraftDocument = Nothing
Sub Main()
seApp = GetObject(, "SolidEdge.Application")
dftDoc = CType(seApp.ActiveDocument, SolidEdgeDraft.DraftDocument)
dftDoc.SaveAs("test.pdf")
End Sub
End Module
It works but name of PDF file is always "Test.pdf".
How get active drawing file name to name of PDF (instead "Test")?
Thank you.
Mike
Posted by: Michal
Post date: 4/5/2012 8:25:12 AM
1 REPLY
Re: File name for Save as PDF
Mike,
below your code with the required changes:
Module Module1
Public seApp
Sub Main()
 dftDoc.SaveAs(IO.Path.GetFileNameWithoutExtension(dftDoc.FullName) & ".pdf")
 End Sub
End Module
Posted by: Wolfgang Kunert
Post date: 4/8/2012 2:34:50 AM
