File path in assemblage
Kind time of days!
Question: How in assemblage it is possible to change a detail file path if its (file) have moved to other folder?
Posted by: Dan Sa
Post date: 9/13/2010 2:43:14 AM
RE: File path in assemblage
Dear Danisan,
Use Revision Manager to change the file path.
use the following method.
>> create the object for Revision Manager Application
>> Linked Documents
>> In that Linked Documents search for Required file path
>> Replace the path
>> Update
>> Save
You can find some sample code in SolidEdge Programming Help.
Sandeep
Posted by: Sandeep Shewale
Post date: 9/13/2010 8:50:47 PM
Thanks that have prompted where to look. The following has turned out:
    Dim objApplication As SolidEdge.RevisionManager.Interop.Application
    Dim objDocument As SolidEdge.RevisionManager.Interop.Document
    Dim objLinkedDocuments As SolidEdge.RevisionManager.Interop.LinkedDocuments
    Dim objItem As SolidEdge.RevisionManager.Interop.Document
Private Sub ..........................
        objApplication = New RevisionManager.Application
        objDocument = objApplication.Open("D:\Work\Thing\Thing.asm")
        objLinkedDocuments = objDocument.LinkedDocuments
        objItem = objLinkedDocuments.Item(i)     'Number of the necessary file
        objItem.SetPath("......")  'Specify a New path
End Sub
Posted by: Dan Sa
Post date: 9/16/2010 9:22:03 PM
