Find Top Level Assembly And Make It The Active Document
If a user navigates to a sub component or sub assembly and runs my macro I need SE to find the top level assembly that is currently open (in cache & check out) and change it to the active document.
Anybody have an example of doing this?  Thanks
SEEC/ST2/TCE 7
Posted by: Stephen Lyda
Post date: 11/22/2010 9:27:09 AM
RE: Find Top Level Assembly And Make It The Active Document
Here's a piece of code I used once to find the top-level document. It will need some updating for sync documents and could probably do with a bit of optimizing...
if (document.InPlaceActivated)
    /* Get the parent document */
    SolidEdgeDocument parent = document;
    while (parent.InPlaceActivated)
        object temp = null;
        Array matrix = new double[] { };
        switch (parent.Type)
        case DocumentTypeConstants.igAssemblyDocument:
        case DocumentTypeConstants.igWeldmentAssemblyDocument:
            ((AssemblyDocument)parent).GetContainerDocumentAndMatrixOfIPADoc(out temp, ref matrix);
            break;
        case DocumentTypeConstants.igPartDocument:
            ((PartDocument)parent).GetContainerDocumentAndMatrixOfIPADoc(out temp, ref matrix);
            break;
        case DocumentTypeConstants.igSheetMetalDocument:
            ((SheetMetalDocument)parent).GetContainerDocumentAndMatrixOfIPADoc(out temp, ref matrix);
            break;
        case DocumentTypeConstants.igWeldmentDocument:
            ((WeldmentDocument)parent).GetContainerDocumentAndMatrixOfIPADoc(out temp, ref matrix);
            break;
        case DocumentTypeConstants.igUnknownDocument:
        case DocumentTypeConstants.igDraftDocument:
        default:
            break;
        if (temp != null)
            parent = (SolidEdgeDocument)temp;
        else
            /* If we get here then we couldn't find the top-level document */
            throw new ApplicationException("Couldn't find the top-level document");
Posted by: Calum McLellan
Post date: 11/22/2010 9:30:11 PM
