Find Whereuse Documents in Insight Server
Hi All,
Can anyone provide an example how to use the FindWhereUsedOnServer Method in the Insight Class Library (API)
The help file shows the parameters for the method but not an example on how to use it.
Public Overridable Function FindWhereUsedOnServer ( _
NumberOfProperties As Integer, _
ListOfProperties As Object, _
NumberOfSharePointDirectories As Integer, _
ListOfSharePointDirectories As Object, _
NumberOfDocuments As Integer, _
ListOfDocumentsForWhereUsed As Object, _
<OutAttribute> ByRef NumberOfUserFiles As Integer, _
<OutAttribute> ByRef DocumentsUsedByList As Object, _
TypeOfSearch As Object _
) As Integer
Thanks!
Sergio
Posted by: Sergio Vallejo
Post date: 6/15/2012 3:06:23 PM
