Find objects selected when creating a feature
Has anyone done the following?
Create for example in SE part a derived curve or a offset surface from some model.
Is there a possibility to programmatically find out what the selected edges resp. faces were.
I've tried using solid edge spy, but i can't find it there. I can find the faces of the offset surface, but not where they are offsetted from.
Anyone?
Posted by: Kris Verheyen
Post date: 8/21/2007 3:38:49 AM
