Find related Draft Document for Part Document
Hi all.
I want write code in VB. It must to find draft document, which related with active (or known) Part document, and get it (draft document's) properties.
Please, help me! Solid Edge SPY didn't help me(((
Posted by: Anton Bykov
Post date: 6/8/2010 2:30:24 AM
RE: Find related Draft Document for Part Document
You must use the RevisionManager to find the Draft
Dim objApp As RevisionManager.Application
Set objApp = CreateObject("RevisionManager.Application")
'Path_Name is a string where you have the Drafts.
objApp.WhereUsedCriteria("*.dft", False) = Path_Name
'first Draft
draft_name1 = objApp.FindWhereUsed(part_name)
'for more drafts for the Part call:
draft_name2 = objApp.FindWhereUsed()
in loop
Posted by: JR
Post date: 6/8/2010 8:25:34 PM
JR, I try use follow code:
    Dim objApp As SolidEdgeFramework.Application
    Dim objRev As RevisionManager.Application
    Dim objRevDft As RevisionManager.Document  'Right?
    Set objApp = GetObject(, "SolidEdge.Application")
    Set objRev = CreateObject("RevisionManager.Application")
    pathName = OccDoc.Path '---path "D:\TestVb"
    partName = OccDoc.Name '---name of document "Test.par"
    objRev.WhereUsedCriteria("*.dft", False) = pathName '---As String
    objRevDft = objRev.FindWhereUsed(partName) '---As Object
    dftName = objRevDft.FullName '---As String
    MsgBox dftName  '----Nothing display----
    Set objApp = Nothing
    Set objRev = Nothing
Something wrong, becouse dftName is nothing.
Post date: 6/9/2010 1:34:50 AM
the partName must be a FullName with path in "objRevDft = objRev.FindWhereUsed(partName)"
and objRevDft is a String and not Object
Posted by: JR
Post date: 6/9/2010 2:01:12 AM
JR, yeah, it worked, thank you!
And now I want to get properties this draft document without open it. Is it posible?
Post date: 6/9/2010 2:21:31 AM
Yes, with SolidEdgeFileProperties:
Dim objpropSets As SolidEdgeFileProperties.PropertySets
Dim objprops As SolidEdgeFileProperties.Properties
Dim objprop As SolidEdgeFileProperties.Property
Set objpropSets = CreateObject("SolidEdge.FileProperties")
Call objProps.Open(dftName)
Set objProps = objProps("Custom")
Set objProp = objProp(YourPropName) 'YourPropName is the name of the property as String
'or for all properties
For i = 0 To propSets.Count-1
List1.AddItem (propSets(i).Name)
For j = 0 To propSets(i).Count-1
ListView1.AddItem (" " & propSets(i)(j).Name & " = " & propSets(i)(j).Value)
Next j
Next i
'don't forget all object set to nothing and close the propsets
objpropSets.Close
have fun
JR
Posted by: JR
Post date: 6/9/2010 2:49:33 AM
Thank you!
It's realy useful!!!
Post date: 6/9/2010 6:23:32 PM
I slightly corrected your code:
Set objropSets = CreateObject("SolidEdge.FileProperties")
Call objpropSets.Open(dftName)
Set objprops = objpropSets.Item("Custom")
Set objprop = objprops.Item(YourPropName)
One more question. Is it posible to get options of sheets (SheetSetup.SheetSizeOption) without open draft document?
Thank you again!
Post date: 6/9/2010 6:37:55 PM
Posted By Frantic on 06/09/2010 11:37 PM
Thank you again!
Post date: 6/9/2010 7:17:04 PM
not that I know
Posted by: JR
Post date: 6/9/2010 7:42:14 PM
