Find the functions of a line in drawing
I would like to find the type of function that is drawing in a drawingview to automatically change the color of these lines
I have search in the drawing property but no result
Posted by: BONNAUDET eric
Post date: 10/5/2010 3:10:44 AM
RE: Find the functions of a line in drawing
You mean colour for one line or all lines in the same style? If you need re-coloured all lines, you can change whole line style.
Set objDoc = objApp.ActiveDocument
Set ObjLinearStyles = objDoc.LinearStyles
ObjLinearStyles("Normal").Color = 0              '0=RGB value
Posted by: Jiri Marek
Post date: 10/11/2010 2:50:29 AM
no, I want to change only the color of a function (extrusion)
Post date: 10/11/2010 2:56:08 AM
Bonnaudet,
If you are trying to show the lines corresponding to a extrusion in the part file in a deretermined colour, you simply can't do that by programming or by hand.
The relation between a 3d operation and the corresponding drawing lines is simply not exposed.
I think that this is becasue you can't relate those in all situations, because some edges could result from intersections, projections, etc.
The only thing you can do is "Paint Faces" in 3D and obtain shaded drawing views in 2D.
regards,
Julian
Posted by: Julian Guillo
Post date: 10/13/2010 2:29:20 AM
Thanks Julian
Post date: 10/25/2010 9:10:28 PM
