Finding StartCommand numbers in SolidEdgeSpy
Jason,
I attend PLM World 2006 this year and sat in on your entire presentation. I saw some really great stuff.
I know that Greg has advised against the use of the StartCommand codes to fire off functions with SE, but I have found that a great many functions can only be accessed this way. I thought I saw you use Solid Edge Spy to return the StartCommand codes live from a running instance of SE, but have been unable to duplicate it with my installation.
Did I misremember your demo, or am I just missing something?
Scott
Posted by: Scott Dawson
Post date: 5/23/2006 11:47:32 PM
RE: Finding StartCommand numbers in SolidEdgeSpy
Scott,
I demo'd how to use the constants to start a command. Greg was commenting that you shouldn't use the actual constant value to start a command. Solid Edge Spy will only show you the constant name which is what you should use when calling StartCommand(). Hope this helps.
Posted by: Jason Newell
Post date: 6/8/2006 6:08:33 AM
