Finding specific Table object
I am attempting to populate a table in a draft file. However, there does not appear to be any way of finding a specific table, except by index or table title. Is anyone else aware of a way to do this.
In my case I have tables on three separate sheets and none of them have a title. So how can I distinguish which one is which through the api.
here are the properties and methods associated with SolidEdgeDraft.Table
AnchorPoint
Application
Cell
ColumnHeaderPosition
Columns
Delete
Margin
MaximumRows
PageGap
Parent
ReverseDisplayOrder
Rows
SetOrigin
ShowColumnHeader
TableStyle
Titles
Update
Note there is also no Layer or AttributeSet listed, so I can't even use them to figure it out.
Thanks in advance.
Carl Breving
S&C Electric Co.
Posted by: Carl Breving
Post date: 5/1/2012 1:37:07 PM
Re: Finding specific Table object
Carl,
you can add one more invisible Column to the end of each Table (Show property set to False) and set its Header property to any name you want to search for.
Then you check for the table name by doing the following comparison:
' Find a specific table in the active draft document
Dim objDoc As SolidEdgeDraft.DraftDocument = objApp.ActiveDocument
Dim strTableName As String = "MyTable"
For Each objTable As Table In objDoc.Tables
If Not objTable.Columns.Item(objTable.Columns.Count).Show And _
  objTable.Columns.Item(objTable.Columns.Count).Header = strTableName Then
  ' Table found
End If
Next
Posted by: Martin Bernhard
Post date: 5/3/2012 5:26:09 AM
