FiniteRevolvedProtrusion
I am workin on a bit of code that would automate the creation of O-rings, but i am stuck on creating the revolved feature, and would appreciate any help. When running the code it works all the way to the model creation, then i get an error message. I am kind of new to SE automation so any suggestions are welcome.
The code is below:
_____________________________________________
Imports SolidEdgeConstants
Imports System.Runtime.InteropServices
Module Module1
    Sub Main()
        Dim objApplication As SolidEdgeFramework.Application = Nothing
        Dim objDocuments As SolidEdgeFramework.Documents = Nothing
        Dim objPart As SolidEdgePart.PartDocument = Nothing
        Dim objProfileSets As SolidEdgePart.ProfileSets = Nothing
        Dim objProfileSet As SolidEdgePart.ProfileSet = Nothing
        Dim objProfiles As SolidEdgePart.Profiles = Nothing
        Dim objProfile As SolidEdgePart.Profile = Nothing
        Dim objRefPlanes As SolidEdgePart.RefPlanes = Nothing
        Dim objRefPlane As SolidEdgePart.RefPlane = Nothing
        Dim objRelations2d As SolidEdgeFrameworkSupport.Relations2d = Nothing
        Dim objRelation2d As SolidEdgeFrameworkSupport.Relation2d = Nothing
        Dim objLines2d As SolidEdgeFrameworkSupport.Lines2d = Nothing
        Dim objLine2d As SolidEdgeFrameworkSupport.Line2d = Nothing
        Dim aLine(0 To 3) As SolidEdgeFrameworkSupport.Line2d
        Dim objModels As SolidEdgePart.Models = Nothing
        Dim objModel As SolidEdgePart.Model = Nothing
        Dim objRounds As SolidEdgePart.Rounds = Nothing
        Dim objRound As SolidEdgePart.Round = Nothing
        Dim objAxes As SolidEdgePart.RefAxes = Nothing
        Dim aProfile As Array
        Try
            objApplication = Marshal.GetActiveObject("SolidEdge.Application")
            objDocuments = objApplication.Documents
            objPart = objDocuments.Add("SolidEdge.PartDocument")
            objRefPlanes = objPart.RefPlanes
            objRefPlane = objRefPlanes.Item(3)
            objProfileSets = objPart.ProfileSets
            objProfileSet = objProfileSets.Add()
            objProfiles = objProfileSet.Profiles
            objProfile = objProfiles.Add(objRefPlane)
            objLines2d = objProfile.Lines2d
            objRelations2d = objProfile.Relations2d
            aLine(0) = objLines2d.AddBy2Points(0, 0.02, 0.0045, 0.02)
            aLine(1) = objLines2d.AddBy2Points(0.0045, 0.02, 0.0045, 0.0227)
            aLine(2) = objLines2d.AddBy2Points(0.0045, 0.0227, 0, 0.0227)
            aLine(3) = objLines2d.AddBy2Points(0, 0.0227, 0, 0.02)
            objRelations2d.AddKeypoint(aLine(0), KeypointIndexConstants.igLineEnd, aLine(1), KeypointIndexConstants.igLineStart)
            objRelations2d.AddKeypoint(aLine(1), KeypointIndexConstants.igLineEnd, aLine(2), KeypointIndexConstants.igLineStart)
            objRelations2d.AddKeypoint(aLine(2), KeypointIndexConstants.igLineEnd, aLine(3), KeypointIndexConstants.igLineStart)
            objRelations2d.AddKeypoint(aLine(3), KeypointIndexConstants.igLineEnd, aLine(0), KeypointIndexConstants.igLineStart)
            objAxes = objProfile.SetAxisOfRevolution(objLines2d.AddBy2Points(0, 0, 0.1, 0))
            aProfile = Array.CreateInstance(GetType(SolidEdgePart.Profile), 1)
            aProfile.SetValue(objProfile, 0)
            objModels = objPart.Models
            objModel = objModels.AddFiniteRevolvedProtrusion(aProfile.Length, aProfile, objAxes, SolidEdgePart.FeaturePropertyConstants.igLeft, Math.PI)
        Catch ex As Exception
            Console.WriteLine(ex.Message)
            Console.ReadKey()
        End Try
        If Not (objApplication Is Nothing) Then
            Marshal.ReleaseComObject(objApplication)
            objApplication = Nothing
        End If
        If Not (objDocuments Is Nothing) Then
            Marshal.ReleaseComObject(objDocuments)
            objDocuments = Nothing
        End If
        If Not (objPart Is Nothing) Then
            Marshal.ReleaseComObject(objPart)
            objPart = Nothing
        End If
        If Not (objProfileSets Is Nothing) Then
            Marshal.ReleaseComObject(objProfileSets)
            objProfileSets = Nothing
        End If
        If Not (objProfileSet Is Nothing) Then
            Marshal.ReleaseComObject(objProfileSet)
            objProfileSet = Nothing
        End If
        If Not (objProfiles Is Nothing) Then
            Marshal.ReleaseComObject(objProfiles)
            objProfiles = Nothing
        End If
        If Not (objProfile Is Nothing) Then
            Marshal.ReleaseComObject(objProfile)
            objProfile = Nothing
        End If
        If Not (objRefPlanes Is Nothing) Then
            Marshal.ReleaseComObject(objRefPlanes)
            objRefPlanes = Nothing
        End If
        If Not (objRelations2d Is Nothing) Then
            Marshal.ReleaseComObject(objRelations2d)
            objRelations2d = Nothing
        End If
        If Not (objRelation2d Is Nothing) Then
            Marshal.ReleaseComObject(objRelation2d)
            objRelation2d = Nothing
        End If
        If Not (objLines2d Is Nothing) Then
            Marshal.ReleaseComObject(objLine2d)
            objLines2d = Nothing
        End If
        If Not (objLine2d Is Nothing) Then
            objLine2d = Nothing
        End If
        If Not (objModels Is Nothing) Then
            Marshal.ReleaseComObject(objModels)
            objModels = Nothing
        End If
        If Not (objModel Is Nothing) Then
            Marshal.ReleaseComObject(objModel)
            objModel = Nothing
        End If
        If Not (objRounds Is Nothing) Then
            Marshal.ReleaseComObject(objRounds)
            objRounds = Nothing
        End If
        If Not (objRound Is Nothing) Then
            Marshal.ReleaseComObject(objRound)
            objRound = Nothing
        End If
        If Not (objAxes Is Nothing) Then
            Marshal.ReleaseComObject(objAxes)
            objAxes = Nothing
        End If
    End Sub
End Module
Re: FiniteRevolvedProtrusion
Ah, you were so close!
 should be
Dim objAxis As SolidEdgePart.RefAxis = Nothing
Notice that it's "RefAxis", not "RefAxes"...
FYI, I referenced the SolidEdgeCommunity / Samples on GitHub to see working code to compare against. Specifically, I looked at the PartHerlp.vb class of the ApiDemos project and searched for keyword SetAxisOfRevolution.
I would also like to mention that all of the
If Not (objX Is Nothing) Then
	Marshal.ReleaseComObject(objX)
	objX = Nothing
End If
are not necesesary in this particular scenario. You have a console app that executes the code then exits immediately. The Runtime Callable Wrappers (RCW) live in a single AppDomain and get released automatically when the AppDomain is unloaded, which in this case is when the application exits.
Jason Newell
Solutions Architect
www.jasonnewell.net
Thank you for your help, and thank you even more for the links. The examples will help me learn a lot. I am kind of a copy/paste programmer since i didn't have any serious programming lessons beyond for loops, so i didn' really understand what ReleaseComObject does so i left it. I know it's a bad way to build proframs, but i work with what i have.
Anyway thanks for the help.
Marko
