Flat Pattern Threatment Options
How can I modufy the "Flat Pattern Threatment Options" by API (VB.NET)?
I cannot find this in API. Maybe an other way to open/modify/save many sheet metal documents....
Kind Regards
Marthijn
Re: Flat Pattern Threatment Options
how do you manually make the change you want? Is it sufficient to change the options and your model changes?
Greetings from Germany
Christian Kunkel
https://c-k-m.info
I want to change this options for 20.000 sheet metal parts. Manual it is not doable.
Any idea how to change it by API?
Yes I found the parameter in API:
objDoc.SetGlobalParameter(SolidEdgePart.SheetMetalGlobalConstants.seSheetMetalGlobalFlatPatternInsideCornerTreatmentType, 3)
objDoc.SetGlobalParameter(SolidEdgePart.SheetMetalGlobalConstants.seSheetMetalGlobalFlatPatternInsideCornerTreatmentValue, 0.002)
objDoc.SetGlobalParameter(SolidEdgePart.SheetMetalGlobalConstants.seSheetMetalGlobalFlatPatternOutsideCornerTreatmentType, 3)
objDoc.SetGlobalParameter(SolidEdgePart.SheetMetalGlobalConstants.seSheetMetalGlobalFlatPatternOutsideCornerTreatmentValue, 0.002)
