Framework 2.0 and Framework 1.1 not start SolidEdge
Hi Jason,
i have installed Framework 2.0 and Framework 1.1 and now
my VB.NET Addin (Visual Studio 1.1) does not start SolidEdge.
Can anybody help me...
Posted by: Reza Habibi
Post date: 11/9/2005 8:53:08 PM
RE: Framework 2.0 and Framework 1.1 not start SolidEdge
So you have addin in VB.NET 2003 and it's configured to start Solid Edge when you debug and now it doesn work? Do you get any error messages?
Posted by: Jason Newell
Post date: 11/10/2005 5:47:31 AM
Hi Jasson
yes, i have addin in VB.NET 2003 and it's configured to start Solid Edge.
see the movie...
Post date: 11/10/2005 7:17:30 PM
a new problem...
i set the picture1.Dock property of FILL and this are ignore.
i think i deinstall Framework 2.0
Post date: 11/10/2005 8:15:05 PM
Reza,
If you just build your solution and then open Solid Edge normall, does it open? If so, does your addin show up?
Right now nothing is jump out at me as to why it's not working.
Post date: 11/11/2005 5:00:57 AM
I have experienced problems with Framework 1.1 and 2.0 on the same machine. I think that using VS.Net 2003 and having Framework 2.0 installed will probably never bring much joy (I don't know what the official word from MS is, I'm just going on my own experience...)
Hope this helps
Posted by: Calum McLellan
Post date: 11/11/2005 8:28:01 AM
Jason,
i can build my solution and start SolidEdge normal. My addin show in SolidEdge.
I have deinstall Framework 2.0 and all is OK.
Post date: 11/13/2005 4:32:49 PM
