Freeze Layer
PLM World Member Pioneer PLM World Member Pioneer
Hello All,
Is there a way to freeze a layer in solidedge as in AutoCAD.
I searched the SDK file but dint find any method.
Is there any alternative method to do this?
Thanks You
Shruthi
Re: Freeze Layer
If you know how to freeze a layer in Solid Edge interactively, then the API too is similar.
There are two ways:
1. By using the index of the layer as below:
oLayers.Item(5).Show = False
2. Using the name of the layer:
oLayers.Item("Layer2").Show = False
Tushar Suradkar
http://surfandcode.blogspot.in/
www.cadvertex.com
