From ordered to flat via API
Hi everyone!
Can someone help me to change mode from ordered to flat in a .psm file
using vb.net?
The file is already existent so the flat pattern mode too.
The following step will be to activate cutting feature n.1 -> export .dxf -> suppress n.1
activate cutting feature n.2 -> export .dxf -> suppress n.2
and so on..
thank you in advance !!
Boomic
Re: From ordered to flat via API
Hi pellegrinosrl,
I think you don't have to change mode.
Just enable / disable features as needed, then update the flattend model and export to DXF using the SaveAsFlatDXFEx() method of the Models collection.
JB
SE ST10
