General edge question
Hi Guys,
I am just doing some testing with vb.net and solid edge to see how I am going to write my program.
Basically if I had part like the one attached what in your opinion would be the best way to do this?
Would you set it up as a template (as the part is a standard except for the sizes etc) then copy to the new location then alter through the variables table.
Or would you create from scratch each time?
Craig
[attachment=200]die.jpg[/attachment]
Posted by: Craig Brunton
Post date: 3/25/2013 12:08:14 PM
Just copy and edit the variables. We did a test once and it took longer for SE to make the part from scratch than to copy and edit. Not to mention it's a lot more code to make it from scratch.
Posted by: Terry Tyson
Post date: 3/26/2013 9:34:15 AM
Re: General edge question
Thank you for the reply it was kind of the way I was thinking. I will create the template models then supress the features I dont need the etc. Sent from my GT-N7100 using Tapatalk 2
Post date: 3/27/2013 3:31:30 PM
