Generation of DXF, STP files from PAR or ASM
Hi all,
I would like to use the framework to generate 'dxf' and 'stp' files straight from 'par' or 'asm'. I don't want to have to instantiate solid edge to do so.
Is this even possible? With the right combo of dll's and .net commands, I should be able to open a 'par' file and generate...
Trav
Posted by: Travis May
Post date: 10/23/2012 1:26:10 PM
I should probably note that I am going to package this functionality on a web server so I can generate models for our customers parametrically. We have a product line that varies by width and three frame sections. The permutations prevent us from making every single model. There could potentially be billions of them.
Trav
Post date: 10/23/2012 2:53:09 PM
I like the concept and hope you get the answer you are looking for. I could use this as well. Currently I use the app.
Posted by: Terry Tyson
Post date: 10/23/2012 3:57:50 PM
Apparently, from the guys at SolidEdge, we must have the API for this kind of thing... it's not too bad, I've gotten really good results on time tests and think I'll have something up and running here real soon...
Post date: 11/6/2012 1:54:51 PM
