Get PartList Content
Hi Jason,
       I want to get partlist content, do you know how to get it?
       Now I can get the content from the part's properties of partlist item, but if the draft disconnect with its parts, how I get the content?
       Thanks!
Posted by: Jack Yan
Post date: 9/2/2007 5:53:09 PM
RE: Get PartList Content
Hi Jack and welcome to the forums.
Assuming that the current document in SE is a Draft document, you can get to the parts list like this:
Application -> ActiveDocument -> PartsLists
My Solid Edge Spy program will help you if you're not familiar with the object structure. I'm not exactly sure what you mean by if the draft is disconnected. Are you meaning that the referenced assembly is not available?
Posted by: Jason Newell
Post date: 9/3/2007 5:45:01 PM
Yes, the assembly file cannot be found in the path.
My code as below:
Private Sub Command1_Click()
    Dim i As Integer, j As Integer
    Dim objPartList As PartsList
    Dim objModelNode As ModelNode
    Set ObjSheet = ObjDoc.ActiveSheet
    For i = 1 To ObjSheet.DrawingObjects.Count
        If TypeOf ObjSheet.DrawingObjects(i) Is PartsList Then
            Set objPartList = ObjSheet.DrawingObjects(i)
            Exit For
        End If
    Next
    If objPartList Is not Nothing Then
        ReDim Part(0)
        For i = 1 To objPartList.ModelLink.ModelNodes.Count
            Set objModelNode = objPartList.ModelLink.ModelNodes(i)
            If objModelNode.IncludeInPartsList And objModelNode.IsBallooned Then
                ReDim Preserve Part(UBound(Part) + 1)
                Part(UBound(Part)).ItemNo = objModelNode.ItemNumber
                Part(UBound(Part)).PartNo = GetPartNo(objModelNode.FileName)
            End If
        Next
    End If
End Sub
Function GetPartNo(FullFileName As String) As String
    Dim objPropSet As Object
    Dim objPropSets As Object
    Dim i As Integer
    On Error Resume Next
    Set objPropSets = CreateObject("SolidEdge.FileProperties")
    objPropSets.Open FullFileName
    Set objPropSet = objPropSets.Item("ProjectInformation")
    GetPartNo = Trim(objPropSet.Item("Document Number").Value)
    objPropSets.Close
    On Error GoTo 0
End Function
If the file of "FullFileName" cannot be found, how to get the part number of the file properties?
Thanks!
Posted by: Jack Yan
Post date: 9/3/2007 6:04:13 PM
Jack,
I don't think it's possible unless the referenced file is available because there is no information about the file embedded into the Draft other than it's path.
Post date: 9/3/2007 6:07:16 PM
Jason, Ok. Thanks for your help.
Posted by: Jack Yan
Post date: 9/3/2007 6:17:11 PM
