Get callout values programmatically
Hello again, i need one more help :dry:
I have to change a lot of callout properties in draft documents, there's any way to pick and modify callout collections? I hadn't find this in SDK documentation.
Posted by: Marcelo Marques
Post date: 12/17/2012 11:10:29 AM
It's the objSheet.Balloons collection. Balloons and Call-outs are the same object.
Posted by: Terry Tyson
Post date: 12/18/2012 8:50:22 AM
Try,
objBalloon.DisplayByItemNumber = True
and see if that works for you.
Post date: 1/2/2013 11:43:41 AM
