Get draft dimension by display name
I need to add a subfix to one dimension on a draft.  Is there a way to get that dimension by display name instead of item #?  the Item # will change from draft to draft.
Bob Reinkemeyer
CAD Integration developer
Martin Sprocket and Gear Inc.
Re: Get draft dimension by display name
worst case,  why not seach by name but return the item #? (not sure what "item #" is)
In the attached screenshots my Dimensin is V629 - Named "Hole2Hole"  see the diff Properties for each6-7-2017 3-13-13 PM.png6-7-2017 3-12-58 PM.png
Matt Johnson
Teamcenter 10.1.7
I ended up doing this and got it to work...
foreach (SolidEdgeFrameworkSupport.Dimension dimension in cSE.oDimensions)
var name = dimension.DisplayName;
if (name=="LargeEnd")
dimension.SubfixString = sTaperInfo;
Bob Reinkemeyer
