Get font size for a Balloon , Callout ...
I need to get the font size of the Balloon's text : (or any other dimension object : Callout ...)
I test this :
SolidEdgeFrameworkSupport.Balloon ballon;
double size = ballon.Style.ViewTextRatio;
Console.WriteLine(size); --> it display : 2
Could someone help me please to find the correct property ?
Regards.
Mahbouba
Re: Get font size for a Balloon , Callout ...
Hi Mahbouba,
use the Height property of the DimStyle (unit is meter)
JB
SE ST10
@JB thank you very much.
Problem resolved !
Mahbouba
Just an update :
we use :
Style.Height with a draft document.
and
Style.HeightPMI with a part document
But what about a Sheet Metal document ?
I would imagine that Style.HeightPMI would also work for a sheet metal document. Is this not the case?
Siemens PLM Software, Inc.
Project Test Engineer (Automation)
Unfortunatly , I tried Style.HeightPMI and Style.Height but they dont work.
Dim objDimStyle As SolidEdgeFrameworkSupport.DimStyle
objDimStyle.HeightPMI = 0.02 * 0.0254
also change visible size to "Model Size PMI". then you can see change in PMI text height.
i tried to change chnage the options through program. but i am not upto mark. sorry.
from our group you will get answer for "how to chnage the option through program".
Bala.
