Get isocurve along a surface?
Suppose I have a surface, parameterized by variables u,v.  Holding (say) u fixed at some value and varying v gives us a curve on the surface, and vice versa, and I call curves that arise this way isocurves.  What is the corresponding notion in Solid Edge?  What function can I use to take a surface, supply either a u- or a v-value, and get the resulting isocurve, so that I might e.g. calculate its arc length?
Re: Get isocurve along a surface?
https://docs.plm.automation.siemens.com/tdoc/se/109/se_help/#uid:index#goto:feature_modeling:xid4818...
Matt Johnson
Teamcenter 10.1.6
Thanks for the reply.  But an isocline curve is a different concept (a more geometric one).  I'm just looking for the simpler concept of the curve obtained by fixing a u- or v-value of a surface parameterization.
