Get point coords on draft...help me please
Hello programmers, I'm new entry in this forum (and sorry for my poor english)
I use .NET now and ST3.
My problem is get coordinates point on a draft, on muose click SE event....
I see this post: http://www.jasonnewell.net/Community/Forums/tabid/55/aft/3206/Default.aspx
But I didn't resolved....
This is my poor creation, i try to put coords on Label4:
Imports System.Runtime.InteropServices
Imports SolidEdgeConstants
Imports System
Imports System.IO
Public Class Principale
    Dim WithEvents oComm As SolidEdgeFramework.Command
    Dim WithEvents oMouse As SolidEdgeFramework.Mouse
    Private Sub Principale_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        Dim objApp As SolidEdgeFramework.Application = Nothing
        Dim objType As Type
        Dim oSE As SolidEdgeFramework.Application
        Dim oDFT As SolidEdgeDraft.DraftDocument
        Try
            objApp = Marshal.GetActiveObject("SolidEdge.Application")
        Catch ex As Exception
            'New Visual Basic.NET Syntax ' Get the type from the Solid Edge ProgID
            objType = Type.GetTypeFromProgID("SolidEdge.Application")
            ' Start Solid Edge
            objApp = Activator.CreateInstance(objType)
            ' Make Solid Edge visible
            objApp.Visible = True
            Console.WriteLine(ex.Message)
        Finally
            If Not (objApp Is Nothing) Then
                Marshal.ReleaseComObject(objApp)
                objApp = Nothing
            End If
        End Try
        oSE = Marshal.GetActiveObject("SolidEdge.Application")
        oDFT = oSE.ActiveDocument
        oComm = oSE.CreateCommand(2)
        oMouse = oComm.Mouse
        oComm.Start()
End Sub
Private Sub oMouse_MouseUp(ByVal sButton As Integer, ByVal sShift As Integer, ByVal dX As Double, ByVal dY As Double, ByVal dZ As Double, ByVal pWindowDispatch As Object, ByVal lKeyPointType As Long, ByVal pGraphicDispatch As Object)
        If sButton = 1 Then
            'left mouse button. get coordinates.
            Label4.Text = ("X=" & Format(dX * 1000, "0.00") & vbTab & "Y=" & Format(dY * 1000, "0.00"))
        Else
            'finish. Right mouse button
            End
        End If
    End Sub
End Class
Please help me with an example
Regards, Fabiano
Posted by: metalworld metalworld
Post date: 12/20/2010 7:54:14 PM
RE: Get point coords on draft...help me please
I solved!!!
Post date: 12/21/2010 12:51:26 AM
Posted By metalworld on 21 Dec 2010 06:51 AM
I solved!!!
How did u solve this?
Could you please send the sample code for this?
I am  trying this example to get mouse coordinates. But I am not able to get the coordinates.
Is this the correct way to get the coordinate.
My code
        private void button1_Click_1(object sender, EventArgs e)
            SolidEdgeDraft.DraftDocument document = null;
            try
                document = (SolidEdgeDraft.DraftDocument)m_application.ActiveDocument;
                SolidEdgeFramework.Layer layer = (SolidEdgeFramework.Layer) document.ActiveSheet.Layers.ActiveLayer;
                SolidEdgeDraft.Sheet activeSheet = (SolidEdgeDraft.Sheet)document.ActiveSheet;
                SolidEdgeFramework.Command oComm = m_application.CreateCommand(2);
                SolidEdgeFramework.Mouse oMouse = oComm.Mouse;
                oComm.Start();
            catch (System.Exception ex)
                MessageBox.Show(ex.Message, "Invalid unit");
            finally
                if (document != null)
                    Marshal.ReleaseComObject(document);
                    document = null;
        private void oMouse_MouseUp(int sButton, int sShift, double dX, double dY, double dZ, object pWindowDispatch, long lKeyPointType, object pGraphicDispatch)
            MessageBox.Show("Called");
            if(sButton == 1)
                //left mouse button. get coordinates.
                MessageBox.Show("X=" + dX * 1000 + " Y=" + dY * 1000);
            else
                //tests;
Posted by: Amit Wadekar
Post date: 7/28/2011 2:39:46 AM
