Get scale factor/zoom from active Window/View
the ActiveWindow has a View object and the view implements a ZoomCamera method. You can zoom the camera view by a scale factor. But how to get the current scale factor? I could not find a property for this? Am I just blind?
Thanks!
Posted by: Robin
Post date: 9/21/2012 2:56:24 AM
Robin,
seems that the method <View_Object>.GetCamera(...) is what you are searching for.
Posted by: Wolfgang Kunert
Post date: 9/21/2012 4:20:07 AM
