Get value of custom property from occurrences
Hi all,
I'm creating my own View & Markup for my company, and I want to include some custom properties in there as well. For instance I have a column named "K4-Description" in every model.
I'm currently cycling through all occurences and I have a single function getDescription(SolidEdgeDocument document) that should return the value of "K4-Description". The problem is that property.value or property.getValue() don't work. The debugger gives me the error "Native View", but I can see the value in the debugger.
Do I really have to open each document and then get it? Because with assemblies over 1000 occurrences that would take a long time...
thanks!
___________________________
The truth is .... I am Dutch
VB.NET - C# - VS Ex 2015 - ST10 MP3
Re: Get value of custom property from occurrences
Looks like you are coding for SolidEdge, but this is the NX Programming forum.
You might be better posting in the Solid Edge Developer Forum
Production: [NX8.5.3.3 MP11 64bit] Testing: [NX12.0.0.27 MP1]
Oh sorry, my bad.
Is there an easy way to move this one?
That'll probably have to be done by a forum admin.
Easiest way for you is to create a new topic in the SolidEdge forum and put a link to that in this topic (just for completeness).
