GetAssemblyReferenceKey
How to use the GetAssemblyReferenceKey from a draft. I want to get the assembly occurrence from a partslist modelnode. Anyone an idea?
Kind Regards
Marthijn
Re: GetAssemblyReferenceKey
Hi Marthijn,
the documentation of GetAssemblyReferenceKey() is very poor.
But I did some  ivestigation on the returned Byte array.
I seems, that each model node from an assembly has a unique byte array and the first part of the array is equal for the parent model node (assembly) and all child elements.
You also get such a byte array from method GetReferenceKey() of the Occurrence object, which I assume is equal to that from the corresponding ModelNode.
With this information you could find the right Occurrence /SubOccurrence oject.
I assume you could also use the ComponentName (ModelNode) and Name (Occurrence) properties to parse the tree. But the Name of the Occurrence can be changed by the user. But I think this also reflected in the ModelNode.
I hope this helps, as I never used this in an own program.
JB
SE ST10
