Reply
GetDimensions
[ Edited ]
Hi all,
I need a sample with de GetDimensions method...
Who can help me?
Posted by: Aldo Kruger
Post date: 11/14/2005 3:14:04 AM
RE: GetDimensions
[ Edited ]
Aldo,
There is probably a more elegant way to create an Array in VB.NET than what I used but this also works. You gotta remember, I'm a C# guy. You guys are killin me with the VB.NET syntax .
Let me know how it goes .
Imports System.Collections
Imports System.Runtime.InteropServices
Module Module1
Sub Main()
Dim objApp As SolidEdgeFramework.Application
Dim objDoc As SolidEdgePart.PartDocument
Dim objModel As SolidEdgePart.Model
Dim objExtrudedProtrusion As SolidEdgePart.ExtrudedProtrusion
Dim NumDimentsions As Integer
Dim Dimensions As Array = Array.CreateInstance(Type.GetType("System.Object"), 0)
objApp = Marshal.GetActiveObject("SolidEdge.Application")
objDoc = objApp.ActiveDocument
objModel = objDoc.Models.Item(1)
objExtrudedProtrusion = objModel.ExtrudedProtrusions.Item(1)
objExtrudedProtrusion.GetDimensions(NumDimentsions, Dimensions)
End Sub
End Module
Posted by: Jason Newell
Post date: 11/14/2005 5:27:57 AM
RE: GetDimensions
[ Edited ]
Hi Jason,
some VB.Net syntax
Shared Sub Main()
Dim Dimensions() As Object = New Object() {}
'MessageBox.Show(Dimensions(0).Value)
End Sub
Cheers
Calum
Posted by: Calum McLellan
Post date: 11/15/2005 12:33:35 AM
