GetExactRange in custom CoordinateSystem
Hi guys,
I'd like to know if there is a way to use the GetExactRange method from SolidEdgeGeometry.Body or SolidEdgeGeometry.Edge types in another coordinate system than the default one ?
In my scenario, a user clicks on a coordinate system in a part. From this selected coordinate system, I want to retrieve the exact range of my part.
Thank you very much !
Posted by: David Shooner
Post date: 3/19/2012 6:34:07 AM
Re: GetExactRange in custom CoordinateSystem
Hi David,
you simply set the results in relation to your (translated) custom coordinate system. I don't see the problem.
Posted by: Wolfgang Kunert
Post date: 3/19/2012 9:46:11 AM
