GetExternalLinkInfo Dimension Variable
I want to rename my linked variables and give them the same name as the variable where the link come from, but I have problems with dimensions!
How can I use the GetExternalLinkInfo for a variable with the type dimension?
Example:
Dim ObjVariables As SolidEdgeFramework.Variables
ObjVariables = objDoc.Variables
Dim isLinked As Boolean = True
For Each ObjVariable As SolidEdgeFramework.variable In ObjVariables.Query("*")
Try
If ObjVariable.Formula.Contains("@") Then
If TypeOf ObjVariable Is SolidEdgeFrameworkSupport.Dimension Then
Dim VarName As String = ObjVariable.Name
Dim SourceVariableName As String = ""
Dim SourceDocumentName As String = ""
ObjVariables.Item(VarName).GetExternalLinkInfo(SourceVariableName, SourceDocumentName) 'Here is the problem!!!!!!!!!!
If VarName <> "MaterialThickness" Then
ObjVariables.Item(VarName).Name = SourceVariableName
End If
Else
End If
End If
End If
Catch ex As Exception
End Try
Next
Posted by: marthijn van Leeuwen
Post date: 12/17/2012 8:26:36 AM
