GetRelated with Drawing views
I'm trying to use the GetRelated method to find out what view a dimension belongs to, I realise that I will probably have to do some recursion to get up to the view from the line I'm attached to.
My problem is that I am not getting any data returned, I can find out how many points the dim is related to but not what it is related to e.g. a line. If I Draw In View and attach a dimension to the same line the code returns the line object
Code snippet below
seobject.GetRelated(0, graphicobj1, seX1, seY1, seZ1, seKeyPoint)
seobject.GetRelatedCount(secount)  ' This works and returns a value of 2 i.e. both keypoints
For i = 0 To secount
    Debug.Print(CStr(graphicobj(i).name))
Next
Is this just the API that is broken or am I doing something wrong?
TIA
James
Posted by: James Singleton
Post date: 8/22/2007 3:42:32 AM
RE: GetRelated with Drawing views
Forgot to mention VB.Net VS2005 but have also tried this in VB6
Thanks again
Post date: 8/22/2007 3:44:50 AM
James,
Just a hunch but I'd suspect that you're Index value is what's killing you. Remeber that COM index's are 1 based and not 0 based. Try seobject.GetRelated(1,....)
Posted by: Jason Newell
Post date: 8/22/2007 12:19:12 PM
Hi Jason, thanks for the reponse but thats not it.
Full VB6 code below,
To useSmiley Tonguelace a view in draftAdd dimensionSelect dimensionRun app - Gives count crashes on related itemsRight click on view and Draw in ViewAdd the same dimension againSelect dimensionRun app - Gives count and related item names
Private Sub Command1_Click()
    Dim objApp As Object
    Dim objSheet As Object
    Dim graphicobj As Object
    Dim objDim As Object
    Dim seCount As Long
    Dim seKeyPoint As Boolean
    Dim seX As Double, seY As Double, seZ As Double, i As Long
    'Get SE object
    Set objApp = GetObject(, "SolidEdge.Application")
    Set objDim = objApp.ActiveSelectSet(1)
    Call objDim.GetRelatedCount(seCount)
    MsgBox seCount & " related"
    For i = 0 To seCount - 1
        ' Get the related elements
        Call objDim.GetRelated(i, graphicobj, seX, seY, seZ, seKeyPoint)
        MsgBox "Item " & i & ": " & graphicobj.Name
    Next i
    Set graphicobj = Nothing
    Set objDim = Nothing
    Set objSheet = Nothing
    Set objApp = Nothing
    End
End Sub
Thanks again
Post date: 8/22/2007 11:21:53 PM
your code unfortunately still starts with index 0 in your for loop!
Wolfgang
Posted by: Wolfgang Kunert
Post date: 8/24/2007 12:36:57 AM
Sorry for not getting back to you guys sooner, I've been away and had not had chance to check back.
Wolfgang, The code above works perfectly, well as described above. If it was .NET then I would agree that it should be 1 based.
Does anyone have any other ideas why this does not return any objects when the dimension is attached to a line in a drawing view?
TIA
James
Post date: 9/4/2007 11:00:07 AM
