Getting the routed objects using API
when using the harness module in solid edge, I can route paths throught parts using the commande Route
How can i read information about the routed parts using API?
Best regards,
Amani
Re: Getting the routed objects using API
Hi @Ameni,
I could not find any API to read the information about routed parts.
Can you please file an IR?
Kaustubh
I will do so..
Thank you..
Regards.
Amani
