Gradient Background?
I want to add a feature to an add-in that, upon a save event, would automatically change a part or assembly file's background to the new "Gradient" scheme. I had figured this would be an easy task, but I'm not having any luck. I thought the setting might be in the ViewStyle object, but if it is I don't recognize it.
Any ideas?
Posted by: Ted Barham
Post date: 5/1/2006 3:58:25 AM
RE: Gradient Background?
Ted,
I replied to your post in the SE forums but I thought I'd reply here too in case anyone was curious.
I've looked and looked but I just don't see a way to set the background colors. If I get a chance, I'll ask one of the SE dev guys and see if they know. You can always file an IR too.
Posted by: Jason Newell
Post date: 5/10/2006 8:27:37 PM
So Jason,
Did you ever get to ask the question and get an answer about the gradient background?
Posted by: T Kin
Post date: 10/17/2008 2:53:46 AM
