Group.Layer error
I am trying to get the Layer name that a group is associated to.
The api documentation shows that Layer is a method of SolidEdgeFrameworkSupport.Group
However, when I call this in the following code I get, "Object doesn't support this action" error.
Dim oGroup          As SolidEdgeFrameworkSupport.Group
Dim bStampAltered  As Boolean
If oGroup.Layer "Backgrounds" Then
   bStampAltered = True
End if
Anyone know what I am doing wrong?
Posted by: Carl Breving
Post date: 8/14/2007 12:29:36 PM
RE: Group.Layer error
Apperently this does not work in V15 update 4. It does work in V19, so I'll wait for our upgrade.
Post date: 8/17/2007 10:27:25 AM
