Handle OnFileSaveAsUI and cancel save
Hi community,
I try to handle the OnFileSaveAsUI event in order to define the filename on first save if a name is define by another tool.
Everything works fine except when the user cancel the save, in the UI.
In that case a message appears saying for exemple 'Part1 cannot be saved'.
Code used :
    Private Sub OnFileSaveAsUI(ByRef Filename As String, ByRef AppendToTitle As String) Implements SolidEdgeFramework.ISEFileUIEvents.OnFileSaveAsUI
        If Public_Vars.CustomFilename <> "" Then
            AddOrRemoveEventHandlers(False)
            Dim linksUpdateOption As SolidEdgeFramework.LinksUpdateOption
            Dim selectedfilter As Integer
            Dim strSaveAsFileName As String
            linksUpdateOption = SolidEdgeFramework.LinksUpdateOption.igNoLinksUpdate
            Try
                strSaveAsFileName = MyAddIn.Instance.Application.GetSaveAsFileName(linksUpdateOption, selectedfilter, InitialFilename:=Public_Vars.CustomFilename , FileFilter:="default")
                If Not strSaveAsFileName = "False" Then
                    Filename = strSaveAsFileName
                    Public_Vars.CustomFilename = ""
                Else
                    '## HOW TO EXIT WIHOUT MESSAGE ##
                    Filename = Nothing AppendToTitle = Nothing Public_Vars.CustomFilename = "" End If AddOrRemoveEventHandlers(True) Catch ex As Exception Public_Vars.CustomFilename = "" AddOrRemoveEventHandlers(True) Throw New System.NotImplementedException End Try Else Throw New System.NotImplementedException End If End Sub
Romuald
Re: Handle OnFileSaveAsUI and cancel save
Hi community,
For those who have the same question, here is the solution I come up with :
            Try
                strSaveAsFileName = MyAddIn.Instance.Application.GetSaveAsFileName(linksUpdateOption, selectedfilter, InitialFilename:=Public_Vars.CustomFilename, FileFilter:="default")
            End Try
            Else
                Filename = Nothing
                Throw New System.Runtime.InteropServices.COMException(String.Empty, 1)
            End If
        Else
        End If
Romuald
