Harness size with C#
I'm working with ST8 and Solid edge harness.
I'm able to read the harness components and connections but  I'm searching for a methode to get the harness height and width.
What should i do exactly?
Thank you
Re: Harness size with C#
Hi @Ameni,
Can you please explain more on about harness height and width that you are interested in?
It would be great if you can give reference of SE command which returns these values.
Kaustubh
