Harnesses CreateFromNetlistImporter gives E_FAIL
I'm trying to automate Wire-Harness creation similar to Wizard for it.
I'm using Harnesses member function CreateFromNetlistImporter for the job.
I've got to the point where (based on errors I got) it seems to recognize the "Company" properly (as import format that is), but I still get E_FAIL for the result of the method.
I tested the component and connection files in Wizard and they work there without any warnings.
I'm also calling the COM with STA modeled thread, but still get the same error.
Any idea how to proceed?
Posted by: Kalle Launiala
Post date: 10/17/2011 7:11:03 PM
