Reply
Help in customization
[ Edited ]
I am new to solid edge programming. I am in the process of customizing in Solid edge assembly and drawing. I would like to know whether the following points are possible in customization.
1) Can I customize for creating Display Configuration ? (I require to hide some components and subbassembly and store in a display configuration)2) If I generate drawing through customization, sometimes few dimensions are not regenerating. can I delete the dimensions which are not regenerated using customization?
I am very new to customization. It would be great if you guide me in learning solid edge programming. Any reference material or learning material would be helpful.
Thanks to all.
Thiyagarajan.
Posted by: thiyagarajan d
Post date: 1/19/2012 12:40:18 AM
