Help me! In Dimensions....
I'm developing an integration of Solid Edge with an ERP, and must see the dimensions used in the model. Got to get the size that the model is presented, but an error occurs when I'm initially working with a traditional paper and read the size of it and then move to a model synchronized. The moment I try to read the dimensions of the synchronous model is the following error:
"Retun argument has type is invalid."
This error always occurs when I open the document of a type (sinconizado or traditional) and without closing the Solid Edge, I open the other ...
I'm using VB.NET 2008 and the Solid Edge ST
Thank you!
===========Conection Object===============
Imports Microsoft.VisualBasic
Imports Microsoft.Win32
Imports SolidEdgeFramework
Imports SolidEdgeConstants
Imports System
Imports System.Collections
Imports System.Reflection
Imports System.Runtime.InteropServices
Imports System.Windows.Forms
Namespace IntegraSE
    ''' Esta é a Classe Base para Solid Edge Addin.
    ''' Se usar este projeto como um template, terá que gerar um novo GuidAttribute e atualizar o ProgId se você mudar o nome.
    _
    Public Class Addin
        Implements SolidEdgeFramework.ISolidEdgeAddIn, SolidEdgeFramework.ISEAddInEvents
        Private addin As SolidEdgeFramework.AddIn
        Private application As SolidEdgeFramework.Application
        Private connectionPoints As New Hashtable
#Region "Membros de ISolidEdgeAddin"
        Public Sub OnConnection(ByVal Application As Object, ByVal ConnectMode As SolidEdgeFramework.SeConnectMode, ByVal AddInInstance As SolidEdgeFramework.AddIn) Implements SolidEdgeFramework.ISolidEdgeAddIn.OnConnection
            'Informa a versão GUI
            AddInInstance.GuiVersion = 1
            'Alimenta as variáveis para usar depois
            Me.addin = AddInInstance
            Me.application = Application
            Try
                'SolidEdgeFramework.ISEddInEvents
                HookEvents(Me.addin, New Guid("{0F539244-4816-11D2-B5AC-080036E8B802}"))
            Catch ex As Exception
                MessageBox.Show(ex.Message, "Erro na conexão dos eventos.", MessageBoxButtons.OK, MessageBoxIcon.Error)
            End Try
        End Sub
        Public Sub OnConnectToEnvironment(ByVal EnvCatID As String, ByVal pEnvironmentDispatch As Object, ByVal bFirstTime As Boolean) Implements SolidEdgeFramework.ISolidEdgeAddIn.OnConnectToEnvironment
            Dim commandNames(4) As String
            Dim commandIDs(4) As Integer
            Try
                commandNames(0) = (String.Format("Cadastro{0}Cadastro da Peça / Conjunto{1}Cadastro da Peça / Conjunto{2}Cadastro da Peça / Conjunto", ControlChars.Lf, ControlChars.Lf, ControlChars.Lf))
                commandNames(1) = (String.Format("Banco{0}Cadastro do Sistema de Gestão{1}Cadastro do Sistema de Gestão{2}Cadastro do Sistema de Gestão", ControlChars.Lf, ControlChars.Lf, ControlChars.Lf))
                commandNames(2) = (String.Format("Configura{0}Configurações{1}Configurações{2}Configurações", ControlChars.Lf, ControlChars.Lf, ControlChars.Lf))
                commandNames(3) = (String.Format("Ajuda{0}Ajuda{1}Ajuda{2}Ajuda", ControlChars.Lf, ControlChars.Lf, ControlChars.Lf))
                commandNames(4) = (String.Format("Sobre{0}Sobre o IntegraSE{1}Sobre o IntegraSE{2}Sobre o IntegraSE", ControlChars.Lf, ControlChars.Lf, ControlChars.Lf))
                commandIDs(0) = 101
                commandIDs(1) = 102
                commandIDs(2) = 103
                commandIDs(3) = 104
                commandIDs(4) = 105
                addin.SetAddInInfo(Marshal.GetHINSTANCE(Me.GetType().Module).ToInt32(), EnvCatID, "IntegraSE", 1, 2, 1, 2, commandIDs.Length, commandNames, commandIDs)
                'If (bFirstTime) Then
                Dim environment As SolidEdgeFramework.Environment
                environment = pEnvironmentDispatch
                environment.CommandBars.Add("IntegraSE", SolidEdgeFramework.SeBarPosition.seBarTop, False, False)
                'Botão Cadastro
                Dim btnCadastro, btnBanco, btnConfigura, btnAjuda, btnSobre As SolidEdgeFramework.ISECommandBarButton
                btnCadastro = addin.AddCommandBarButton(EnvCatID, "IntegraSE", 101)
                btnCadastro.LoadFace(My.Application.Info.DirectoryPath + "\Cadastro.bmp")
                btnCadastro.Caption = "Cadastro da Peça / Conjunto"
                btnCadastro.DescriptionText = "Cadastro da Peça / Conjunto"
                btnCadastro.TooltipText = "Cadastro da Peça / Conjunto"
                'Botão Banco
                btnBanco = addin.AddCommandBarButton(EnvCatID, "IntegraSE", 102)
                btnBanco.LoadFace(My.Application.Info.DirectoryPath + "\Banco.bmp")
                btnBanco.Caption = "Cadastro do Sistema de Gestão"
                btnBanco.DescriptionText = "Cadastro do Sistema de Gestão"
                btnBanco.TooltipText = "Cadastro do Sistema de Gestão"
                'Botão Configura
                btnConfigura = addin.AddCommandBarButton(EnvCatID, "IntegraSE", 103)
                btnConfigura.LoadFace(My.Application.Info.DirectoryPath + "\Configura.bmp")
                btnConfigura.Caption = "Configurações"
                btnConfigura.DescriptionText = "Configurações"
                btnConfigura.TooltipText = "Configurações"
                'Botão Ajuda
                btnAjuda = addin.AddCommandBarButton(EnvCatID, "IntegraSE", 104)
                btnAjuda.LoadFace(My.Application.Info.DirectoryPath + "\Ajuda.bmp")
                btnAjuda.Caption = "Ajuda"
                btnAjuda.DescriptionText = "Ajuda"
                btnAjuda.TooltipText = "Ajuda"
                'Botão Sobre
                btnSobre = addin.AddCommandBarButton(EnvCatID, "IntegraSE", 105)
                btnSobre.LoadFace(My.Application.Info.DirectoryPath + "\Lógica.bmp")
                btnSobre.Caption = "Sobre o IntegraSE"
                btnSobre.DescriptionText = "Sobre o IntegraSE"
                btnSobre.TooltipText = "Sobre o IntegraSE"
                'End If
                MessageBox.Show(ex.Message)
            End Try
        End Sub
        Public Sub OnDisconnection(ByVal DisconnectMode As SolidEdgeFramework.SeDisconnectMode) Implements SolidEdgeFramework.ISolidEdgeAddIn.OnDisconnection
            On Error Resume Next
            UnhookEvents()
        End Sub
#End Region
#Region "Membros de ISEAddinEvents"
        Public Sub OnCommand(ByVal CommandID As Integer) Implements SolidEdgeFramework.ISEAddInEvents.OnCommand
            'Para saber os números dos comandos usar o SolidEdgeSpy.exe (Jason Program)
            'application.StartCommand(57601)
            Select Case CommandID
                Case 101 'Cadastro
                    Dim objDocumment As SolidEdgeFramework.SolidEdgeDocument = Nothing
                    objDocumment = application.ActiveDocument
                    If Not (objDocumment Is Nothing) Then
                        If objDocumment.Type SolidEdgeFramework.DocumentTypeConstants.igPartDocument And objDocumment.Type SolidEdgeFramework.DocumentTypeConstants.igAssemblyDocument _
                        And objDocumment.Type SolidEdgeFramework.DocumentTypeConstants.igSheetMetalDocument And objDocumment.Type SolidEdgeFramework.DocumentTypeConstants.igSyncAssemblyDocument And _
                        objDocumment.Type SolidEdgeFramework.DocumentTypeConstants.igSyncPartDocument And objDocumment.Type SolidEdgeFramework.DocumentTypeConstants.igSyncSheetMetalDocument And _
                        objDocumment.Type SolidEdgeFramework.DocumentTypeConstants.igWeldmentAssemblyDocument And objDocumment.Type SolidEdgeFramework.DocumentTypeConstants.igWeldmentDocument Then
                            MessageBox.Show("O documento aberto é inválido para cadastro!", "IntegraSE", MessageBoxButtons.OK, MessageBoxIcon.Information)
                        Else
                            'Verifica a permissão
                            If Permissão() = True Then
                                Dim Cadastro As New Cadastro
                                Cadastro.pApplication = application
                                Cadastro.ShowDialog(New SolidEdgeFwk.ApplicationWindow(application.hWnd))
                            Else
                                MsgBox("O Sistema de Gestão deve estar aberto nesta estação!", MsgBoxStyle.Critical, "IntegraSE")
                                Exit Sub
                            End If
                        End If
                    Else
                        MessageBox.Show("Não há documentos abertos!", "IntegraSE", MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
                    End If
                Case 102 'Banco
                    'Verifica se o Banco de Acesso está setado
                    If My.Settings.BancoAcesso Nothing Then
                            Dim Banco As New Banco
                            Banco.ObjChamada = "Botão"
                            Banco.ShowDialog(New SolidEdgeFwk.ApplicationWindow(application.hWnd))
                        Else
                            Exit Sub
                        End If
                    Else 'senão
                        'Avisa o Usuário
                        MsgBox("Gerenciador do Banco de Dados não está Definido!", MsgBoxStyle.Critical, "IntegraSE")
                    End If
                Case 103 'Configura
                    Dim Configura As New Configura
                    Configura.ShowDialog(New SolidEdgeFwk.ApplicationWindow(application.hWnd))
                Case 104 'Ajuda
                    MessageBox.Show("Não Implementado")
                Case 105 'Sobre
                    Dim Sobre As New Sobre
                    Sobre.ShowDialog(New SolidEdgeFwk.ApplicationWindow(application.hWnd))
            End Select
        End Sub
        Public Sub OnCommandHelp(ByVal hFrameWnd As Integer, ByVal HelpCommandID As Integer, ByVal CommandID As Integer) Implements SolidEdgeFramework.ISEAddInEvents.OnCommandHelp
        End Sub
        Public Sub OnCommandUpdateUI(ByVal CommandID As Integer, ByRef CommandFlags As Integer, ByRef MenuItemText As String, ByRef BitmapID As Integer) Implements SolidEdgeFramework.ISEAddInEvents.OnCommandUpdateUI
        End Sub
#End Region
#Region "Classe de Funções Privadas"
        ''' Método customizado para manipular "hooking" nos eventos do Solid Edge
        Private Sub HookEvents(ByVal source As Object, ByVal eventGUID As Guid)
            Try
                ' Converte o source usando a interface UCOMIConnectionPointContainer.
                Dim connectionPointContainer As UCOMIConnectionPointContainer = source
                Dim connectionPoint As UCOMIConnectionPoint
                If Not (connectionPointContainer Is Nothing) Then
                    ' Responde como um objeto conectável somente se  possui um ponto de conexão para uma GUID particular,
                    ' e retorna a interface IConnectionPoint para o ponto de conexão.
                    connectionPointContainer.FindConnectionPoint(eventGUID, connectionPoint)
                    If Not (connectionPoint Is Nothing) Then
                        Dim cookie As Integer = 0
                        ' Estabelece conexão entre o ponto de conexão e a chamada do objeto.
                        connectionPoint.Advise(Me, cookie)
                        If (cookie 0) Then
                            ' Add the UCOMIConnectionPoint to the Hashtable.
                            connectionPoints.Add(connectionPoint, cookie)
                        Else
                            Throw New System.Exception("A Conexão entre o ponto de conexão e o objeto chamado falhou.")
                        End If
                    End If
                Else
                    Throw New System.Exception("Fonte não implementada IConnectionPointContainer.")
                End If
                Throw ex
            End Try
        End Sub
        '''Método personalizado para remover qualquer hooks adicionados aos eventos.
        Private Sub UnhookEvents()
            Try
                ' Unadvise the UCOMIConnectionPoint objects.
                Dim enumerator As IDictionaryEnumerator = connectionPoints.GetEnumerator()
                While (enumerator.MoveNext())
                    connectionPoint = enumerator.Key
                    connectionPoint.Unadvise(enumerator.Value)
                End While
                ' Clear the Hashtable
                connectionPoints.Clear()
            End Try
        End Sub
#End Region
#Region "Funções Regasm.exe"
        ''' Specifies the method to call when you register an assembly for use from COM; this allows for the execution of user-written code during the registration process.
        _
        Public Shared Sub RegisterFunction(ByVal t As Type)
            Dim baseKey As RegistryKey
            Dim summaryKey As RegistryKey
            Dim title As AssemblyTitleAttribute
            Dim description As AssemblyDescriptionAttribute
            Try
                title = AssemblyTitleAttribute.GetCustomAttribute(t.Assembly, Type.GetType("System.Reflection.AssemblyTitleAttribute"))
                description = AssemblyDescriptionAttribute.GetCustomAttribute(t.Assembly, Type.GetType("System.Reflection.AssemblyDescriptionAttribute"))
                baseKey = Registry.ClassesRoot.CreateSubKey("CLSID\{" & t.GUID.ToString & "}")
                If Not (baseKey Is Nothing) Then
                    ' Write required registry entries for a Solid Edge Addin.
                    baseKey.SetValue("AutoConnect", 1)
                    baseKey.SetValue("409", title.Title)
                    baseKey.CreateSubKey("Implemented Categories\" & SolidEdgeConstants.CATIDS.CATID_SolidEdgeAddIn)
                    ' The following keys determine which environments your addin will connect to.
                    baseKey.CreateSubKey("Environment Categories\" & SolidEdgeConstants.CATID_SEApplication)
                    baseKey.CreateSubKey("Environment Categories\" & SolidEdgeConstants.CATID_SEAllEnvironmentDocuments)
                    'baseKey.CreateSubKey("Environment Categories\" & SolidEdgeConstants.CATID_SEAssembly)
                    'baseKey.CreateSubKey("Environment Categories\" & SolidEdgeConstants.CATID_SEDraft)
                    'baseKey.CreateSubKey("Environment Categories\" & SolidEdgeConstants.CATID_SEPart)
                    'baseKey.CreateSubKey("Environment Categories\" & SolidEdgeConstants.CATID_SESheetMetal)
                    'baseKey.CreateSubKey("Environment Categories\" & SolidEdgeConstants.CATID_SEWeldment)
                    ' This will be the Description text that is displayed in the SE Addin Manager.
                    summaryKey = baseKey.CreateSubKey("Summary")
                    If Not (summaryKey Is Nothing) Then
                        summaryKey.SetValue("409", description.Description)
                        summaryKey.Close()
                    End If
                    baseKey.Close()
                End If
            Catch
            End Try
        End Sub
        ''' Specifies the method to call when you unregister an assembly for use from COM; this allows for the execution of user-written code during the unregistration process.
        _
        Public Shared Sub UnregisterFunction(ByVal t As Type)
            'On Error Resume Next
            ' Remove any previously written registry entries.
            Try
                Registry.ClassesRoot.DeleteSubKeyTree("CLSID\{" + t.GUID.ToString() + "}")
            End Try
            Try
                CleanupSolidEdgeCurrentUser(Registry.CurrentUser.OpenSubKey("Software\Unigraphics Solutions\Solid Edge"), "{" + t.GUID.ToString() + "}")
            End Try
        End Sub
        ''' Solid Edge does not automatically cleanup some addin entries under HKEY_CURRENT_USER.  This recursive function will delete only keys that match the GUID of this addin.
        Public Shared Sub CleanupSolidEdgeCurrentUser(ByVal key As RegistryKey, ByVal guid As String)
            Dim subkeys() As String
            ' Get all SubKeys names for the passed RegistryKey.
            subkeys = key.GetSubKeyNames()
            For Each subkey As String In subkeys
Posted by: Fabio Rosa
Post date: 4/7/2009 4:40:00 AM
