Help me please!
Tell me about how do I add images to the buttons I'm creating this code .... when I open the Solid Edge is only the text but not in the form of a button ....
Please, if anyone knows what to do, answer me!
See the code below the class
Imports System.Runtime.InteropServices
Imports Microsoft.Win32
Imports System.Reflection
Imports System.Collections
Imports System.Collections.Generic
ProgIdAttribute("IntegraSE.Integra"), _
ComVisible(True)> _
Public Class Integra
    Implements SolidEdgeFramework.ISolidEdgeAddIn, SolidEdgeFramework.ISEAddInEvents
    Private objAddin As SolidEdgeFramework.AddIn
    Private objApplication As SolidEdgeFramework.Application
    Public Sub OnConnection(ByVal Application As Object, ByVal ConnectMode As SolidEdgeFramework.SeConnectMode, ByVal AddInInstance As SolidEdgeFramework.AddIn) Implements SolidEdgeFramework.ISolidEdgeAddIn.OnConnection
        objAddin = AddInInstance
        objApplication = Application
        AddInInstance.GuiVersion = 1
        AddInInstance.Description = "Integração com Forwood / Fabril / SIG"
    End Sub
    Public Sub OnConnectToEnvironment(ByVal EnvCatID As String, ByVal pEnvironmentDispatch As Object, ByVal bFirstTime As Boolean) Implements SolidEdgeFramework.ISolidEdgeAddIn.OnConnectToEnvironment
        Dim commandNames As Array = Array.CreateInstance(GetType(String), 2)
        Dim commandIDs As Array = Array.CreateInstance(GetType(Integer), 2)
        Try
            commandNames.SetValue(String.Format("Cadastro{0}Cadastro da Peça / Conjunto{1}Cadastro da Peça / Conjunto no Sistema de Gestão{2}Cadastro da Peça / Conjunto no Sistema de Gestão", ControlChars.Lf, ControlChars.Lf, ControlChars.Lf), 0)
            commandNames.SetValue(String.Format("Estrutura{0}Visualização Conjunto / Montagem{1}Visualização Conjunto / Montagem{2}Visualização Conjunto / Montagem", ControlChars.Lf, ControlChars.Lf, ControlChars.Lf), 1)
            commandIDs.SetValue(1, 0)
            commandIDs.SetValue(2, 1)
            objAddin.SetAddInInfo(Marshal.GetHINSTANCE(Me.GetType().Module).ToInt32(), EnvCatID, "IntegraSE", 1, 2, 1, 2, commandIDs.Length, commandNames, commandIDs)
            If bFirstTime Then
                Dim Environment As SolidEdgeFramework.Environment
                Environment = pEnvironmentDispatch
                Environment.CommandBars.Add("IntegraSE", SolidEdgeFramework.SeBarPosition.seBarTop, False, False)
                objAddin.AddCommandBarButton(EnvCatID, "IntegraSE1", 1)
                objAddin.AddCommandBarButton(EnvCatID, "IntegraSE2", 2)
            End If
        Catch ex As Exception
            MsgBox(ex.Message)
        End Try
    End Sub
    Public Sub OnDisconnection(ByVal DisconnectMode As SolidEdgeFramework.SeDisconnectMode) Implements SolidEdgeFramework.ISolidEdgeAddIn.OnDisconnection
        If Not (objAddin Is Nothing) Then
            objAddin = Nothing
        End If
        If Not (objApplication Is Nothing) Then
            objApplication = Nothing
        End If
    End Sub
    _
    Public Shared Sub RegisterFunction(ByVal t As Type)
        Dim baseKey As RegistryKey = Nothing
        Dim summaryKey As RegistryKey = Nothing
        Dim title As AssemblyTitleAttribute
        Dim description As AssemblyDescriptionAttribute
        Try
            baseKey = Registry.ClassesRoot.CreateSubKey("CLSID\{" + t.GUID.ToString + "}")
            baseKey.SetValue("AutoConnect", 1)
            If t.Assembly.IsDefined(GetType(AssemblyTitleAttribute), True) Then
                title = AssemblyTitleAttribute.GetCustomAttribute(t.Assembly, GetType(AssemblyTitleAttribute))
                baseKey.SetValue("409", title.Title)
            End If
            If t.Assembly.IsDefined(GetType(AssemblyDescriptionAttribute), True) Then
                description = AssemblyDefaultAliasAttribute.GetCustomAttribute(t.Assembly, GetType(AssemblyDescriptionAttribute))
                summaryKey = baseKey.CreateSubKey("Summary")
                summaryKey.SetValue("409", description.Description)
                summaryKey.Close()
            End If
            'Addin
            baseKey.CreateSubKey("Implemented Categories\{26B1D2D1-2B03-11d2-B589-080036E8B802}")
            'All Envirenment Documents
            baseKey.CreateSubKey("Environment Categories\{BAD41B8D-18FF-42c9-9611-8A00E6921AE8}")
        Finally
            If Not (summaryKey Is Nothing) Then
                summaryKey.Close()
            End If
            If Not (baseKey Is Nothing) Then
                baseKey.Close()
            End If
        End Try
    End Sub
    _
    Public Shared Sub UnregisterFunction(ByVal t As Type)
        Try
            Registry.ClassesRoot.DeleteSubKeyTree("CLSID\{" + t.GUID.ToString + "}")
        End Try
    End Sub
    'Addin Events
    Public Sub OnCommand(ByVal CommandID As Integer) Implements SolidEdgeFramework.ISEAddInEvents.OnCommand
    End Sub
    Public Sub OnCommandHelp(ByVal hFrameWnd As Integer, ByVal HelpCommandID As Integer, ByVal CommandID As Integer) Implements SolidEdgeFramework.ISEAddInEvents.OnCommandHelp
    End Sub
    Public Sub OnCommandUpdateUI(ByVal CommandID As Integer, ByRef CommandFlags As Integer, ByRef MenuItemText As String, ByRef BitmapID As Integer) Implements SolidEdgeFramework.ISEAddInEvents.OnCommandUpdateUI
    End Sub
End Class
Posted by: Fabio Rosa
Post date: 2/16/2009 7:32:01 AM
RE: Help me please!
Answered in previous post. I'm locking this one.
Posted by: Jason Newell
Post date: 2/17/2009 1:50:01 PM
