Help needed : Accessing the Selection Manager??
Please help me out...How to access the selection manager in SE?? eg. I want to add the picked faces to the selection manager,and process them within my command..
Sincerely,Sandip
Posted by: Sandip Karale
Post date: 5/20/2011 1:50:23 AM
3 REPLIES 3
RE: Help needed : Accessing the Selection Manager??
Sandip,
check the SelectSet object in the programming help.
Posted by: Wolfgang Kunert
Post date: 5/31/2011 5:23:03 AM
Thanks Wolfgang Kunert,
I am trying to select the faces on the mouse click, I have used SelectSet and added the face one by onebut the faces are not get displayed as picked faces ( not highlighted ), do i need to change the style of the facesmanually and keep track of them or any api available to do this operation...
Sincerely,Sandip
Post date: 6/1/2011 2:18:31 AM
Sandip,
to highlight programmatically selected objects you have to also add them to a HighlightSet object which then is added to the HighlightSets object of the document object. Or better, add your selected objects first to a HighlightSet object and then add the HighlightSet object to the SelectSet object.
Post date: 6/1/2011 3:51:36 AM
