Help with SweptProtrusion
I am looking for help with SweptProtrusion API. I am trying to do this with a SyncPart, but working example in a traditional part would be great.
 Private Sub Command1_Click()
    Dim objApp As SolidEdgeFramework.Application
    Dim objPart As SolidEdgePartSync.PartDocument
    Dim objRefPlanes As SolidEdgePartSync.RefPlanes
    Dim objRefPlane As SolidEdgePartSync.RefPlane
    Dim objSketches As SolidEdgePartSync.Sketchs
    Dim objSketch As SolidEdgePartSync.Sketch
    Dim objProfiles As SolidEdgePartSync.Profiles
    Dim objProfile As SolidEdgePartSync.Profile
    Dim objLines2d As SolidEdgeFrameworkSupport.Lines2d
    Dim objLine2d As SolidEdgeFrameworkSupport.Line2d
    Dim objPoints2d As SolidEdgeFrameworkSupport.Points2d
    Dim objPoint2d As SolidEdgeFrameworkSupport.Point2d
    Dim objRefPlaneNormal As SolidEdgePartSync.RefPlane
    Dim objSketchCS As SolidEdgePartSync.Sketch
    Dim objProfileCS As SolidEdgePartSync.Profile
    Dim objLines2dCS As SolidEdgeFrameworkSupport.Lines2d
    Dim lngTraceCurveTypes(1 To 2) As Long
    Dim lngCrossSectionTypes(1 To 2) As Long
    Dim vOriginArray(2) As Variant
    Dim TraceCurveSet(1) As Object
    Dim EdgeSet(1 To 4) As Object
    Dim objModel As SolidEdgePartSync.Model
    Dim X1 As Double
    Dim Y1 As Double
    Dim X2 As Double
    Dim Y2 As Double
    Dim Z As Double
    Dim xx As Double
    Dim yy As Double
    Const WIDTH As Double = 0.01
    Const HEIGTH As Double = 0.02
    X1 = 0.1
    Y1 = 0
    X2 = 0.1
    Y2 = 0.1
    Z = 0.1
    ' Connect to a running instance of Solid Edge
    Set objApp = GetObject(, "SolidEdge.Application")
    ' Create a new part document
    Set objPart = objApp.Documents.Add("SolidEdge.DMPartDocument")
    ' Get a reference to the ref planes collection
    Set objRefPlanes = objPart.RefPlanes
    ' Get a reference to the sketches collection
    Set objSketches = objPart.Sketches
    Set objRefPlane = objRefPlanes.AddParallelByDistance(objRefPlanes(0), Z, SolidEdgePartSync.ReferenceElementConstants.igNormalSide, , , False)
    Set objSketch = objSketches.AddByPlanarFace(objRefPlane)
    Set objProfile = objSketch.Profile
    Set objLines2d = objProfile.Lines2d
    Set objLine2d = objLines2d.AddBy2Points(X1, Y1, X2, Y2)
    Set objRefPlaneNormal = objRefPlanes.AddNormalToCurve(objProfile.CurveBody.Curves(1), igCurveStart, objRefPlanes(0), igPivotStart, False)
    Set objSketchCS = objSketches.AddByPlanarFace(objRefPlaneNormal)
    Set objProfileCS = objSketchCS.Profile
    Set objLines2dCS = objProfileCS.Lines2d
    Call objProfileCS.Convert3DCoordinate(X1, Y1, Z, xx, yy)
    xx = xx - (WIDTH / 2)
    With objLines2dCS
        .AddBy2Points xx, yy, xx + WIDTH, yy
        .AddBy2Points xx + WIDTH, yy, xx + WIDTH, yy - HEIGTH ' 2mm deep
        .AddBy2Points xx + WIDTH, yy - HEIGTH, xx, yy - HEIGTH
        .AddBy2Points xx, yy - HEIGTH, xx, yy
    End With
    lngTraceCurveTypes(1) = igProfileBasedCrossSection
    lngCrossSectionTypes(1) = igProfileBasedCrossSection
    vOriginArray(1) = 0
    Set EdgeSet(1) = objProfile.CurveBody.Curves(1)
    Set EdgeSet(2) = objProfile.CurveBody.Curves(2)
    Set EdgeSet(3) = objProfile.CurveBody.Curves(3)
    Set EdgeSet(4) = objProfile.CurveBody.Curves(3)
    Set TraceCurveSet(1) = objProfile.CurveBody.Curves(1)
'' This didnt work either
'    Set objModel = objPart.Models.AddSweptProtrusion(1, TraceCurveSet, lngTraceCurveTypes, 1, EdgeSet, lngCrossSectionTypes, vOriginArray, 0, igLeft, igNone, 0, Nothing, igNone, 0, Nothing)
'' Not how to struture all these parameters
    Set objModel = objPart.Models.AddSweptProtrusion(1, objProfile, lngTraceCurveTypes, 1, objProfileCS, lngCrossSectionTypes, vOriginArray, 0, igLeft, igNone, 0, Nothing, igNone, 0, Nothing)
    Set objApp = Nothing
    Set objPart = Nothing
    Set objRefPlanes = Nothing
    Set objSketches = Nothing
        Set objRefPlane = Nothing
        Set objSketch = Nothing
        Set objProfiles = Nothing
        Set objProfile = Nothing
        Set objLines2d = Nothing
        Set objLine2d = Nothing
        Set objPoints2d = Nothing
        Set objPoint2d = Nothing
'        Set edgeSet = Nothing
    Set objRefPlaneNormal = Nothing
    Set objSketchCS = Nothing
    Set objProfileCS = Nothing
    Set objLines2dCS = Nothing
    Set TraceCurveSet(0) = Nothing
    Set TraceCurveSet(1) = Nothing
    For i = 1 To 4
        Set EdgeSet(i) = Nothing
    Next i
    Set objModel = Nothing
End Sub
Posted by: David Stonely
Post date: 1/19/2010 4:37:53 AM
RE: Help with SweptProtrusion
I found an old example i did for someone else in the SE programming newsgroup.
Find it attached.
Julian
Posted by: Julian Guillo
Post date: 1/19/2010 5:14:25 AM
Julian,
Thanks for the help. Your example had enough hints to help me out.
David
Here is my functional Code for searchers
    Dim lngTraceCurveTypes(1 To 1) As Long
    Dim lngCrossSectionTypes(1 To 1) As Long
    Dim vOriginArray(1 To 1) As Variant
    Dim TraceCurveSet(1 To 1) As Object
    Dim EdgeSet(1 To 1) As Object
    Dim X1 As Double
    Dim Y1 As Double
    Dim X2 As Double
    Dim Y2 As Double
    Dim Z As Double
    Dim xx As Double
    Dim yy As Double
    X1 = 0.1
    Y1 = 0
    X2 = 0.1
    Y2 = 0.1
    Z = 0.1
    objProfile.End igProfileClosed
    With objLines2dCS
    End With
    objProfileCS.End igProfileClosed
    vOriginArray(1) = 0
    Set EdgeSet(1) = objProfileCS
        Set EdgeSet(1) = Nothing
End Sub
Post date: 1/19/2010 8:47:47 AM
