Hi, I try to use MinimumDistance from Circle to Face but I also get error from the face. If I use Mi
I also try to use MinimumDistance from Circle to Face but I also get error from the face.
If I use MinimumDistance between 2 Circles, It works.
Did you found how to define the face and use it in MinimumDistance???
Please let me know.
Best Regards,
Amir Zeltzer
amir@mckit.co.il
"Piotr J?drkowiak" wrote in message news:...
> hi,
> I have to get a minimum distance from the Part Document using VB.2005.
> I've thic method, but it won't to work:
> partDoc.GetMinimumDistance(face2, face, distToCurrent, point1, point2)
> Throws an exception with Hex number...
> Please help me,
> Regards,
> Piotr Jedrkowiak
Posted by: amir zeltzer
Post date: 9/8/2008 5:28:49 AM
